 - Dec 13, 2006
My swedge grinding is bad to poor, I think alot of its is layout and knowing how to execute.  Anyone know of a tutorial or video that may help?
Thanks
			Thanks
Price is $300 $250 ea (shipped within CONUS).  If you live outside the US, I will contact you after your order for extra shipping charges.
I've always done mine on the grinder after heat treat. If you have a table on your grinder and a piece of 2" X 2" or 3" X 3" angle iron at least a 1' long all you need to do is clap the blade to the angle iron and set the platen at the angle you want to grind. The angle iron will hold the blade the same every time. Do a few trial runs before you do the real thing.
Raymond,
I'm having a hard time picturing that but it sounds like it would work really well. I'll have to figure out exactly what you mean and give it a shot:thumbup: I guess I'm just wondering why you need the angle iron. If you set your table at the desired angle and lay the flat portion of the blade on the table, you can get a nice even grind on both sides if you use gentle, consistent strokes. How does the angle iron help? Thanks!
	I use a sine plate and stroke sander.![]()
Johnny, I am picturing RR's setup like this...Please let me know if I was incorrect Ray.
Patrice Lemée;10685873 said:Thanks Raymond, I will give that a try. My clip grinding is about as good as Patrick's (OP).
Patrice Lemée;10685813 said:The jig is no help with curved clips is it? Never tried it but I don't see how it would work. Not putting the bubble jig down mind you, to the contrary, I would love to be able to use it for curved clips as this is how I mostly do them.![]()
