I'd say belt grind one in on a tall harpoon like that, you can practice first. As far back as that goes I'd do one with a plunge, there doesn't look like enough room for a smooth transition to the spine. It doesn't have to be near sharp either. Mine range between 15 to 20 degrees mostly. On a lower thumb ramp style it's 50/50, thicker blades more likely to get one than thinner ones. Example, if this is 3/32" I'd say no. 1/8" probably and thicker then definitely.
ETA by the way, nice profile~ You can use tape to control the start and stop locations. I often tape the tip so I stop early to leave the tip wider for extra strength. You'll probably have a distal taper so grind harder towards the back and let up gradually so you're just feathering as you approach the tip. That way the top will be even thickness all the way along the swedge.
