- Dec 19, 2006
How do you guys rate Swiss Army knives and Leatherman knives? Is one better than the other? Are they too different to compare?
They are so different it's not even funny! The only crossovers are the Swisstools vs. standard Leatherman tools and the Leatherman lockbacks vs. 111mm locking folders.
The latter one was the comparison that I'm wondering about. For example:
Yeah i'm not a big fan of spine mounted Philips at all, regardless of make. The end mount phillips is definitely more useful.The spine Phillip's on the OH Trekker is not as useful as the end-mount Phillip's on the Leatherman. The Leatherman knives with the bit drivers have a bit of an advantage if you need to screw different types of screws, the Vic is the better camp tool. Now to throw some fuel on the fire, how come you didn't ask about the Wenger Ranger 120mm locking folders (see http://www.wengerna.com/browse/browse.jsp?cat_id=1&sub_cat_id=85) in your comparison?
It does seem to get loose at the pivot point with use, though.
Supratentorial:
Most basic Vic SAKs are slipjoints, but my old Vic Trailmaster is one of the larger-sized SAKs that has a dual linerlock (locks both the knife blade and the bottle/can opener on the other end. I also have an even older Vic Cowboy with a sliding/button lock.
Jim
Jim,
Thank you for the reply. I'm more of a "tool guy" than a "knife guy" so hopefully you and the other members of bladeforums can help straighten me out. So the OHT and Trailmaster have a liner lock similar to the Leatherman C305 except it's on the opposite side.
The large flat driver also uses a liner lock but the remaining tools are slip joints. Correct so far? No here's my main question: The knife on the OHT has what appears to be a back spring which seems to keep the blade from rotating freely. (1) Does this backspring work similar to the way a slipjoint works? (2) What mechanism performs this function on the Leatherman C305?
Some locking blades have a backspring similar to a slipjoint (usually the lock back style as seen on Buck 110s), however, it is noticeably weaker (mostly it is used to hold the blade closed); the backspring in the Vic is not weaker though (which makes opening it a little slower and harder than many Tactical knives, on the other hand if the lock does fail it will not close as easily as other locking blades). Liner locks typically do not have backsprings, they operate similar to a Friction Folder. I've never held or looked closely at a Leatherman C305 (or other Leatherman knife) so I have no idea if they have a backspring at all.
Like Sunshaker said.
On the Leatherman knife I have, there is no backspring, and the way it's held closed is by a ball detent which, on this particular knife, instead of the common ball bearing in the locking liner, the "ball" appears to be a stamped-on bump in the liner. It seems to serve its purpose fine, however.
Jim
