I was using my Swiss Champ this evening, and I noticed something that I hadn't noticed previously. When the large blade is closed, the tip of the blade appears to be touching the base of the file (which is next to it). At first I was concerned that the blade edge could be damaged if it hits the file upon flicking the blade closed, but I don't think this is happening. I do notice a little scuffed area on the left side of the blade tip where it looks to be slightly abraded from rubbing against the base of the file from opening and closing these two implements. When the blade is opened it appears to be perfectly straight, but when it is closed the blade seems to have enough flex in it to allow the tip to brush up against the file.
Has anyone noticed this on their Swiss Champ. Should I send it back to Victorinox, or just be conscious enough of this issue to be careful when opening and closing the blade? Is this a common thing? I have a Recruit, a Super Tinker, a Craftsman, Swiss Champ Plus, and a couple of Wengers that have the blades set perfectly straight in their channel when closed.
Thanks for any comments.
