Simply turn on the VFD, select my speed and direction, then turn on the three phase switch at the grinder I want to run. Works great!
hmmm...this doesn't sound good to me. It is hard to argue with success...but let me just throw my thoughts out there for debate/consideration.
Somwhere, I think I came across a document about VFD...and strong warnings about using them as a Buss source of 3ph power....such that the VFD is always on with muliple motors on standby ready to run by throwing the selected switch.
The way I understood this warning was something like this: VFD's operate with feedback from the motor that they are running by monitoring back-EMF, current and voltage. Based on the feedback from the motor, the VFD will respond accordingly. When the motor is disconnected from the VFD while in operation, the VFD may sense a fault and shut off....or may respond erractically to get the motor to recover. I don't know the technical details but only understood that it is not an ideal practice. I would speculate that it may cause erractic power surges and possible damage to the VFD. After all, the VFD is designed to start and stop the motor with built in canned cycles for accel and decel. The VFD also has motor protection features and some may shut off if they detect a dropped leg.
In my feable mind, I imagine the analogy of driving your car.....then when you want to stop, you turn off the ignition. Now, the brakes and power steering don't work. This is a feature of the car that was designed to operate when the car is running..by turning the car off, you've disabled these important features. Same with the VFD. It has designed features for starting, running and stopping the motor. Use it to do this. So for multiple motors, turn the VFD off, connect the motor of choice, then restart the VFD and use the VFD to operate the motor. Don't leave the VFD on...then switching your selected motor on and off downstream.
Again, you can't argue with success. If you are doing this, and it is working...never mind what I'm saying. I'm just uncomfortable with the idea...but honestly can't provide any technical merit...so, this is just my opinion.
Now I'm 2 cents poorer
-Rob
