Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Every now and then a close friend, or in this case, my boss at work
will entangle me to make a fixed blade sheath, which is NOT something that I would be taking orders for but in his case, pun intended, he needed one to hold his aged knife as his old sheath disintegrated and fell off his belt recently. And wanting to keep peace in the office I grudgingly complied.
The leather is not as thick as I would like to use making a fixed blade sheath but it far out does his old sheath so he will be ok with it.
I made the entrance of the sheath a bit wider opening to allow easier return of the blade, while the lower portion of the sheath is just snug enough to help retain the knife if the snap comes undone by accident. Also this makes the handle not push back against the back drop of the sheath.
But he wanted to be able to swivel the sheath, as he saw one I did on another large knife recently. Thinking that if he could swivel the knife forward when he goes to sit down it would be handier and I agree that is a big help.
So on this I have a back drop of leather coming up from the sheath which protects the wearer and behind that I put on a glued together belt loop and fastened it to the backdrop using a large copper rivet. I put some mink oil paste between the two pieces to help to make it swivel smoother.
He enjoys hunting and looked over my embossing stamps and liked the deer one but also the fish, but settled on the deer. So I went ahead and embossed the back of the belt loop with the fish, in retrospect I would have placed my markings and month/year a little lower but didn't want to be too low, as that was all done before the belt loop piece was glued up.
There are three inner layers on each side of the welt, with the center one running the length of the sheath. The two smaller welt pieces were sanded down to help blend it in and not be too abrupt.
Here are some images, I hope it will give some of you guys and gals some ideas about using a swivel like this as well as making the opening a little wider to make a better fit up, it was much fun hand sewing this up ! NOT lol
Untitled by GaryWGraley, on Flickr
Lying next to his old sheath, the center of his belt loop slit torn apart from dry rot.
The snap strap I placed behind the leather of the sheath, this way when unsnapped it will naturally spring more open and out of the way.
Always good to not run stitching straight across, as that becomes a perforated line and a good place for it to tear in years to come, so I angled them and set two of them, back stitched to keep it from coming undone, also glued in of course.
G2
Untitled by GaryWGraley, on FlickrLying next to his old sheath, the center of his belt loop slit torn apart from dry rot.
Untitled by GaryWGraley, on FlickrThe snap strap I placed behind the leather of the sheath, this way when unsnapped it will naturally spring more open and out of the way.
Untitled by GaryWGraley, on FlickrAlways good to not run stitching straight across, as that becomes a perforated line and a good place for it to tear in years to come, so I angled them and set two of them, back stitched to keep it from coming undone, also glued in of course.
Untitled by GaryWGraley, on FlickrG2
Untitled
Untitled
Untitled
