Mike, would you happen to know the OD of the shaft about 3 inches up from the bottom?
The HD Sword Cane is held in place using rubber washers. As long as these are in good shape it should not rattle - I sell a lot of these and demonstrate this by vigorous shaking. If you trim from the bottom, you will have to find a replacement for the tip. A friend of mine, who is a very serious individual, shortened his from the top, but had to do some careful radiusing because of the slight taper. Was not a problem for him because he used to run a knife company.
The cane sword is pretty heavy compared to a regular cane
Talked with a customer at the Pittsburgh Gun Show this weekend, that had shortened his HD Sword Cane from the bottom. He heated the tip with hot water until he could remove it, shortened the cane, then replaced the tip using silicone to attach it. He is very happy with the way it performs and uses it all the time. Thought I'd pass this on.
