The MSDS for Resiprene says it's melting point is 220 °C (428 °F).
Will the rubber handle 350 degrees needed to make a kydex sheath, don't want to ruin it. I received a silver 311 in a grab bag and a friend offered to make a sheath. He asked if I could find out about the rubber handle's toughness. Thanks
The MSDS for Resiprene says its melting point is 220 °C (428 °F).
You may want to have Dave do it.
Other than potentially melting the handle in the oven, you may mess up the heat treat right? I would definitely not put the knife in the oven.
you will not mess up INFI's heat treat in an oven at 350 degrees. You will be fine. Busse has stated many times that you would have to go over 900 degrees before you affect the HT on INFI.
