Daggers are easy so long as you don't get worried about it. What I see alot of guys doing is trying to line up all the grinds at once. Don't! You will drive yourself crazy trying to.
Treat it as any spearpoint hunter. On the profile, check it by eyeball. If you are unsure, lay it on a piece of paper and carefully trace around it. Turn the blank over and see if it matches. If not make a note and repair that area. Repeat until matched.
Now scribe a center line from tip to pommel (or gaurd for stick tangs). Now scribe your center lines for the cutting edges. Now you want to scribe a line as to where you want your plunges to be.
Grind one bevel at a time. Treat as a non-dagger. Just grind up to your center line and finish off the tip just like any other knife. Repeat this for the remaining three bevels. If your grinds are even your center line at the tip should even out. Slow down your grinder or switch to a smoother belt and even out any little fudges in your grinds. After all your lines are even and balanced, go back and line up all you plunges. If you had tried to line up your plunges and your edge and centerline grinds at the same time, you end up with a mess. It would be like juggling chainsaws while driving a race car across water. Just not possible. Line up one element at a time.
