sometimes they are a tad short or the liner/scales are cut a tad cut too deep, etc and allows that. annoying as all out but shouldnt really affect function. course im assuming its just a tad short etc not enough to fail during proper use.
spyderco should fix it for ya if ya feel its too annoying. sometimes people fix it themselves with various products to stop it from sliding so easily, but taking apart a spyderco typically will void the warranty so keep that in mind. so id send it in before doing it yourself. plus none of these solutions to fix yourself are all that great.
That's not what the boilerplate says.
Spydercos warranty does not cover damage caused by abuse, misuse, loss, improper handling, alterations, accident, neglect, disassembly, or improper sharpening.
So a loose pin is different and prior to taking it apart.
If you strip threads, lose screws, pry apart stuff not meant to be pried open, grind, saw, cut, drill, remove metal or other destructive measures while you dismantle the knife the warranty will not cover that kind of damage.
