- Aug 2, 2004
Hello all,
I have just got a "scorpion's tail" and I have to say this is the first TOPS knife I own that Im not to impressed with.
The designe looked interesting and usefull but when I held it in my hand it became clear that it was full of errors, The handle with finger ring, is made for someone with 6 fingers ( it fits the hand much beter if you dont use the ring, which is the whole point of a karambit, right ?) the finger hole is nearly big enough to put my arm through ! even with gloves it is a horibly dislocated felling you get from the handle. The blade is a good shape but is to small in comparison to the rest of the knife so im not actually convinced of its usefull-nes.
The sheath designe is almost a good one, the deploy and re-sheathing method is interesting (similar to Hossom karambit) but dosant have a clip so over looks one giant thing ! the karambit is a knife most commonly held in the Sunang or reverse grip with your index finger through the hole, so im interested in how TOPS expect you to deploy this as a neck knife ???. It is far more sensible to be puling the knife up away from you, ie. belt mounted. This is a big problem because the karambit is infinatly more powerful and easy to use in a reverse grip so makes it a hiderance to you rather than a help if you have to deply it the other way !!!
In my view the handle should be half an inch shorter, the finger ring should have a smaller diameter, the blade size should be increased by a third and the sheath should have a clip so you can have the luxury of a choice of carry !!! like the street scalpel, a well thought out designe and a much safer and better investment for your cash, than a badly designed karambit.
Play safe
Haze :grumpy:
Play safe
Haze :grumpy:
