Tactical Knives
For those of you who never read it, here's the Tactical Knives article written on our khukuris about 8 months ago. It's reprinted with permission of the author:
<font face="Verdana, Arial" size="2">
I've always been a fan of big blades. In my line of work as a survival instructor/wilderness video producer, I spend a lot of my time chopping, shaping and carving wood and bone. During the 30 years I've been doing this sort of thing, I've learned that you can use a big knife to do a small job but you can't use a small knife to do a big job. The khukuri is the epitome of a big blade. [Editor's note: this is the spelling for "kukri" that those closest to Nepal insist is right. Others say that "kukri" is the correct English spelling.]
I've played with khukuri style blades for years. I like the drop of the blade, and the big sweet spot in the belly. Years ago, a good friend of mine, the late Martin Kruse, hammer-forged a khukuri-style blade for me. I used it for years as my primary chopper. I always wondered how the actual blades would stand up to my style of use, but I shied away because I could never find a native khukuri that said anything but "cheap." That is, until I heard about Gurkha House.
Real Khukuris
Recently I received two of the real khukuris from Craig Gottlieb of Gurkha House for testing and review. These genuine Nepalese blades were far cry from the junk I'd seen on sale at gun shows and shops. The two blades both showed the basic design elements of the traditional khukuri: the big curved blade, the traditional notch at the base of the blade and the beefy construction real khukuris are known for. One of the blades sported a full exposed tang with rosewood handle slabs, while the other appeared to use a spike tang construction in a water buffalo horn handle.
One of the things I've wondered about is the function of the notch found at the base of the blade. I've heard all sorts of stories so I thought I'd better check with Craig. He informed me that the cutout is a called the "Cho." He said that it appears on all khukuris, and that it represents Shiva the Hindu God (and the God of War) that governs destruction and transcendence. The deity is usually shown holding a trident in one hand. The crescent-shaped cutout on all khukuris represents Shiva's trident.
Before I went to work whacking, chopping and splitting, I wanted to get some hardness numbers. I sent the blades off to SCK in Clancy, Montana, for a quick RC test. These blades are forged with truck springs, heated in a fire and tempered with a teakettle! MY thought was that control over the tempering process might be a little spotty. I was wrong.
It turned out that the blades were differentially tempered surprisingly well. The spine on the blades read 22 and 25 RC respectively. The midpoint of the belly measured in at 45 and 46 RC and the edge came in at 54 and 55 RC, not bad for some guy squatting around a fire in sandals! The numbers also showed that these blades are soft enough to take some serious abuse and keep a tolerable edge. My bet is that whoever made these blades has a lot of experience under his belt.
Each of the blades was slightly different in construction. One model--the "Panawall"--is a rougher "workhorse" model with pinned handle slabs, and the other--the "Bhojpure"--has a finer fit and finish. Both blades feature sheaths made of wood wrapped in water buffalo skin. They both came with the traditional Chakma (the dull flint-sparker and crude sharpener) and the Charda, the sharper utility mini-knife.
While my overall impression of the big blades was good, the smaller knives looked crude and rough in design and finish. None of the smaller blades had a sharp edge, and one showed signs of having been burned on the grinding wheel.
I decided to use the heavier blade for my testing, as I wanted to give the Panawal a chance to go to war with one of the many Ponderosa pines that choke my land. We loaded up the camera, the snowmobile, and a first-aid kit, and the cooler (to keep the refreshments warm) and went out in search of a vertical victim.
There is a lot of young growth timber on the land, so I selected a likely candidate for next year's kindling and went to work. The tree had a cross-section of just over 6 inches. I laid into the cold, green wood with vigor and after about 20 hard whacks I had less vigor and a nice sized chunk missing from the tree. 20 more whacks had it leaning and another 10 dropped it. After 50 whacks and a sore arm I checked out the blade. The edged seemed to be about the same as when I started.
During the next two hours I whacked on green limbs, dead branches, old downed timber and free snow kill. My final impression: this blade is a chopping demon. But like all demons it can bite you. The dramatic drop on the blade can cause the knife to twist in your hand upon contact; this twist then gets translated to "get the hell out of the way" energy. If you get tired while using a khukuri, stop using it until you are rested. It didn't bite me, but I can see that it has the potential to be a real shin slicer.
OK…so the thing can chop wood like a chain saw but isn't this supposed to be a combat blade? A blade designed to chop off the limbs of enemies and remove the heads from buffalo? I have a very special test for blades that claim to be tactical choppers--bone chopping.
I've conducted this test on a number of blades in the past. I use a fresh elk leg as the target. Elk bones are large and tough. Over the time I've used the test I've learned that it is a great way to create a serrated blade. The impact of steel with heavy bone has a special property that seems to break chunks out of all but the most stalwart choppers. You can't be light in the loafers when you whack a bone, you've got to get
your wrist into it (now where have you head THAT before?).
Having started bone whacking in adolescence, I confidently confronted the bone and went to work. It only took about 15 whacks to cut through the tough bone, sinew and muscle of the leg. Wow! This thing can cut! Then I looked at the blade; now I had serrated a khukuri.
When I looked at the edge under magnification I could see that some very small pieces had broken off, but the majority of the nicks were just places where the metal had indented under the impact. Ten minutes with a belt sander or some time with a steel should bring this baby back, but I was finished.
Some other points. The brass-tipped sheathes are functional and do a good job holding the blades securely. I noticed that after the testing the leather had become wet, and one of my dogs was strangely attracted to it. A day later I, too, was able to smell the attractant. "Roadkill" would be my description. The belt look is secured to a strap of leather that is compression-fitted to the sheath. This affair soon loosened and the sheath and belt loop parted ways. If I were going to carry one of these big blades I would buy or fashion a secure Kydex sheath for the knife and keep the native sheath for display.
The blade stood up to some severely destructive tests. There was no edge deviation or distortion with standard chopping tests. In fact the edge retention was very good even on the harder knots and dry woods. The bone chop test is severe and some failure is to be expected. If you are looking for a big mean chopper that can denude a mountainside and hope to get it for the right price, this is your baby.
</font>
Hope you enjoyed it!
Craig Gottlieb
Gurkha House
Blade Forums Sponsor
Thanks, I did - and every dime I don't have to squander on magazines usually goes toward buying khukuris, kukris, kuks, etc.
Would someone please be so kind as to let me know the exact reference to this Tactical Knives article which appears about 8 months ago 2000. I have a photocopy of the article, but the magazine's month/year of issue is not shown.
Many thanks indeed!
Doggone it, lost mine, but will look some more. My guess is that it's June 2000, because I bought it just before Army summer camp. Maybe there is a way to e-mail the publisher and find out.
Believe it or not, I don't know either. We were first mentioned in November 1999, but our article was in 2000. Like an idiot, I didn't save the magazine!
I did. I'll look it up and post the date for you later today.
Bob
The Milk Snake: Beautiful, harmless, good-natured, eats venomous snakes for lunch.
Its the Sept 2000 issue. Sorry about not getting back to you guys sooner. Work and school.
Bob
