- Apr 12, 2000
Hello all- I have several custom folders that have a satin finish blade, not a mirror polish but definitely shiny.
I usually use a light coating of REM Oil on my BB and Black blades and the light coating of oil is somewhat soaked in by the seemingly porous nature of these blades, you know how the coating is nice and even, no streaks.
The problem is that when I try to put even a super light coating of the oil on my satin blades there are smudges and streaks.
I put some REM Oil on a cotton ball and put a coating of oil on the blade but I usually wipe it off to leave a very light coating but in the process of wiping it off the smudges and streaks appear, it's almost as if they are smudges from old handling.
Should I totally clean the blade off first ?
I was thinking of doing this but what should I use to remove any oil from fingerprints, etc..?
Or, do I not even have to worry about coating the blade because it is satin finished ?
How about an alcohol based cleaner to remove all traces of oil on the blade prior to the light coating ?
Any tips would be helpful
Thank you, Donald.
Thank you, Donald.
