Taking Knife Pictures
There's gotta be a hundred ways to take knife pictures. And I'm not a professional with a light box and all. However, I used to some work for hire.
In any case here's a method for knife pictures I've found works about everytime:
Pick a bright sunny day. Then find a window in the house on the shady side (no direct sun), preferably a bright room with lots of windows. Place the knife on some fabric (towel, shirt, cool leather jacket) or something. Point the blade toward the window but not right at it. Stand with your shoulder near the window and click away.
Experiment with changing the angle of the blade towards the window and the camera position. And for the big hint: turn the flash off.
Why this method?
1. Problem: Contrast
A strong direct light will create too much contrast. Direct light, like a flash, bouncing of the blade throw the whole light metering system out of wack. A knife has a lot of contrast (shiny blade and wood tones). A single source of light really aggravates the problem.
2. Problem: Shadows
Sharp shadows are unflattering. So no flash (maybe a one stop under flash for fill if you can do it) and no direct sun.
3. Solution: Diffused lighting.
By placing the blade next to a window on the shady side of the house you basically have a wide light source. Also, the other light bouncing around the room will reduce the depths of the shadows. A big white poster board opposite the window can also help - if you want to get fancy.
Here's a photo I took on the kitchen table. The background is the head rest off my Lazy Boy chair:
Here's the same idea, but with my son's bathrobe:
I'm no expert! And there's a lot of knife photos on this site that put me to shame. But I hope that this hint might help somebody in my shoes that doesn't have a full photo shop, light box, etc.
Steve
Thank you. I am, fer sher, one of the world's worse photo takers. I sometimes wonder if the single most time consuming element of knife making is the final part - the photo.
I will try out your suggestion.
Roger
good idea!
or, you can take a big piece of white posterboard and place it at a 45 degree angle between a bright light source and the knife. (it reflects a good amount of light, but its very diffused)
some folks turn their cameras flash straight up and put the white board above them to reflect down on the object. my cameras flash wont do that, so im stuck using another light source.
I have a nikon coolpix 2500, and I can't seem to figure out how to turn the flash off. Can anybody help me with this? I lost the directions. The flash ruins my pictures every time.
Thanks for any help
Kyle Fuglesten
I had good results while photographing outside (not too close of trees or buildings) by a slightly cloudy time.
During sunny days I used a diffuser (a wood frame, approx 4 by 4 feets with white fabrics, not too opaque, or a tissue paper). The diffuser allows to have a uniform lighting on the blade and to soften the light.
Moreover, you can use white cardboards to lighten shadows area (by reflexion) or a small mirror to send light to precise places...
Good luck!
Alain M-D
Kile,
Nikon has a instruction guide on line.
When the camera is in shooting mode, press the flash button to display the flash mode menu.
Press multi selector up or down until desired mode is highlighted
(a circled flash emblem is off)
Press multi selector to right to exit menu (flash-mode menu will also close if no operation is performed for about two seconds). Current flash mode is shown by icon at bottom of monitor
Also, if you use the scene select button, the flash is off in "Museum" mode.
Regards,
Greg
If you're in a pinch, use electrical tape to cover the flash. Just 2-3 layers and it's easy to remove.
For anyone interested, I made a tutorial on taking knife pics with just a regular camera.
I can and have taken much nicer pictures, but I thought that there should be a solution for the everyday Joe who just has a plain-ole camera and wants to take decent pics.
itrade is on the right track - go outdoors if possible. pick a uniformly colored background. Don't use a flash unless you are at a 45 degree angle to the blade (in other words, not perpendicular).
Check out the tutorial sometime and add your input if you like.
It's the last link in my sig line below.
V
