Read this and make sure you understand that convex is not what most tell you it is..
http://www.bladeforums.com/forums/s...ghlight=convex+scandi&p=12539334#post12539334
I think it is near impossible to say anything universal about convex edges since there is an infinite number of ways to make a curved line.
To the OP:
In general, since there is no sharp transition between the edge/secondary bevel and the primary bevel, a convex edge will cut through materials better.
Some say it is stronger, but that all depends on the particular edges you are comparing. Thick is stronger than thin, regardless of edge grind.
After reading the thread posted, and doing some research, I am more lost now than ever. I am not even sure how they are supposed to look, and how to even maintain them. Or anything else for that matter.
Too many people severely overthinking things.
I use both, knives with a convex grind and a good hollow grind. I've noticed when I'm cutting into cheese, cutting up an apple (something firm)or skinning a fat hog. The convex edge requires more pushing to make it cut deeply into these materials than a decent hollow ground blade. When skinning something with fat the tight quarters of the cut will grab the sides of the blade and not allow it to cut deeply. Thus, one thinks it's dull as the hard push required to make it cut. Whereas, in reality it's the thickness of the blade preventing it from cutting. As for it lasting longer like an axe, this may be a valid point. Still, it could be only slight. Yet, I shy away from the convex for this reason. DM
