- Sep 24, 1999
I just received a Talonite Talon from a fellow forumite in a trade and I have the following comments.
The bevels from the factory were greater than twenty degrees. I used a DMT coarse diamond hone to create a fifteen degree back bevel and then put a primary bevel of twenty degrees with a Spyderco Sharpmaker.
I liked the index and thumb notches and notice that they seem to "grip" one way more than the other. I looked at them under a stereo microscope and found that they look like saw teeth and are angled. The handle fits well in my hand.
The knife seemed a little loose in the sheath so I drilled a hole in the spine side of the sheath and added a chicago screw to tighten it up (pictured below).
I like the adjustable belt loop mechanism and the latch mechanism that allows it to be slipped over the belt quickly. I miss the ability to slip it inside the waist band of my pants like you can with the "G" loop setup of other concealex sheaths.
Kevin Miller
My Personal Interests Page
kevinandtrish@sympatico.ca
Look to the Lord and His strength, seek His face always.
Kevin Miller
