The standard advice is to avoid hand sanding where the bolsters go. Reason is the edges of the tang get rounded and you don't have a nice tight fit between the bolsters and the tang. However, If you start sanding right where the bolster ends you'll have sanding start marks on the ricasso.
Just wondering if I'm the only one that does this, but I leave everything oversized until the handle is on. I even leave the slabs way oversized. Then I grind down everthing flush with a 50 grit. Then there are those areas on the edge of the tang where the handsanding left them rounded. There is exposed epoxy there - or the bolsters show a gap.
I just keep grinding until I'm past that. The exposed area is now tight.
I do this in the finger grooves and everything.
Do you do that? Or, do you leave the shape of the blade untouched after the handle is on?
Steve
Steve
