What do they make files from. I thought you couldn't get a hamon on O1?
I grind the profile first, then lay a 45 bevel on each side, or one side depending. I leave a 1/16" at the edge for grinding back/sharpening after heat treating. With the 45s in place I roll the bevel back to my final dimension. That dimention depends on the size of wheel you have, and the proportions of the blade. Look at the JSP Bladerigger site to see what that looks like on a one side bevel. You can flat or hollow grind the main bevel(s) the end should go on flat though. if possible. It's ground the same way: put on a 45 to get your edge thickness, then roll it back to your bevel.
The looks of the knife depend on lots of stuff, but the rake of the chisel tip, the width of the bevel(s), the overall proportions of length to width, and the complementary curves of the back and edge in profile, are key. I don't know what you are after, but I wouldn't want a file profile shape. There should be enough metal in the file to do something interesting, work up a few paterns out of card first to see what you can get out of the proposed piece. Or forge it to shape.
If you are grinding the file, it is possible to grind it without first anealing the steel, I guess it depends on how you are set up to heat treat it. If you don't aneal it, you can't easily get a hamon even if the steel is right, though maybe it can be done with a torch.
Obviously you need to grind the teeth off. which is a pretty quick thing, even with a 1x42.
