- Mar 15, 2002
Made an "Americanized Tanto" with an thin hollow-ground blade. Been trying to get a good solid line, but to no avail. the other blades I've done have been great, but for some reason, this blade is extremely stubborn. I've heat-treated it a few times (with a normalizing treatment between each time.)
At first, I clay-coated the back spine with furnace cement. I heated it up and edged-quenched in ATF. The clay was just to control the hardening line in my quench. Got a low line, but the line on the tip didn't curve up like I wanted.
Did it again with same materials, but with same results.
Last night, I tried something new -- I switched to Canola oil. I only coated the clay on both sides of the spine, but left the back of the spine clay-free. I started heating spine-down to ensure that the spine was getting plenty of heat. Once again I edge-quenched, till the red was gone, then did a full submersion.
The oil was at about 140 degrees, and edge quench in a cheap cake pan, and fully quench in an ammo can.
The steel is 0-1. Any suggestions? I'd like a crisp line for this stubborn knife.
