Tanto or Chisel grind?
Am I imagineing things here or does there seem to be two versions of the BM Stryker out there? I saw a chisel ground version at a gun show this morning, and mine is tanto ground, was the chisel a fluke, or a knock off?
Joe
It's a temporary one, though. They are only making 2500 of them.
Fred
Knife Outlet
www.knifeoutlet.com
Tanto ground and chisel ground? Um, the Stryker is a tanto pointed knife with a conventional grind, though there is a limited run already available of chisel ground tanto Strykers.
Either way you cut it(pun not intended), all variations of the Stryker are tantos.
"All of our knives open with one hand, in case you're busy with the other"
<OVAL OFFICE JOKE>
