Tapered tangs usually do not have handle scales. The tapered tang would be inserted into a handle. Like a soild block of wood with a drilled out area for the tapered tang. Then pinned.
You can have it both ways.I'm not a knife-maker, but from what I've seen, the scales should be parallel to each other. Seems to make sense; other wise, the grip would be more narrow as you go from the blade to the butt.
Oh yeah for sure you can find super high quality blades with straight or tapered and even a stick tang if you're so inclined.Thanx, Danke, of course you can shape the handles to your preferred shape after the glue-up. I've owned several beautiful examples from FiddleBack Forge. Andy Roy states that he builds knives with full tangs and tapered tangs, just because folks tend to prefer one or the other.
I believe that one tang design is about as strong as another, at least until you test the knife to complete destruction...at which point I suspect that the full tang will survive a bit longer than the tapered. (Thicker steel is stronger than thinner steel.) I just note this, as Andy Roy's knives are made with the same care and precision regardless of tang shape.
