I put the profiled blade blank on a 10" long grinding magnet and taper the whole blade portion on the flat platen or on the disc sander. It literally takes seconds per side with a good Blaze belt.
If it is a hidden tang, I taper the whole thing about an inch past the tang shoulders, and then re-verse taper the tang back up to the shoulders. This takes care of the tang as well as the blade taper. Having pre-tapered the tang before adding the bevels will assure easier guard fitting.
On larger full tang knives I taper the blade and then taper the tang toward the butt ... meeting slightly forward of the ricasso/handle junction point. After sanding the blade, the position of the junction will walk back to the perfect spot (hopefully).
If it is a thin bladed full tang, like thin fillet and kitchen blades, I taper the entire blade from butt to tip....leaving the tip about .030" thick. The amount of taper is so small on .060" thick stock that it does not affect the handle installation. For instance - on a 7" blade fillet knife with a 5" handle made in 1/16" stock, the handle portion only tapers about .010" from butt to ricasso. That is a difference of only the thickness of a cheap business card. If you drill the scales while clamped together, the pins will still slip through when on the tapered tang ( unless you drilled the pin holes too tight to start with). At most, you will need a slightly stronger clamp on the front of the scales than on the butt when gluing up the handle. If you drill the scales on the tang, there will be no noticeable angle to the pins, as the divergence is less than a degree.
