- Oct 20, 2004
I just got a mini skirmish and really like it except it is tip down.
Is tapping titanium hard? I notice that the knife has steel inserts that the clip screws into. The clip is also recessed I assume to help with the clip trying to rotate. If I tap it for tip up carry (and probably a wave to go with it) will I run into any problems?
Should I go with 2 screws like it comes with or add a third? Is there a rule about how many threads should be in the Ti? I have heard that with aluminum if you have at least 4 thread in the aluminum you should be ok for strength. Don't know if this is a good rule of thumb but wondering if I should try to find some longer Torx screws that wil go the whole thickness of the Ti or if 2/3 of the way thru would be sufficient.
Any thoughts on this would be greatly appreciated!
Ryan
Ryan
