- Jan 10, 2003
How or what do you use to clean up tarnish and rust? And keep it off of your blade?
My question is - can you use Renaissance Wax on guns? Will it protect them against rust?
To remove, start with WD-40 on paper towel. Just spray on enough to soak the blade. Let it sit for about five minutes to penetrate, and wipe off. You may need to repeat this four or five times.
Another option for rust is a bathroom cleaner called CLR (Calcium, Lime and Rust remover). I've had good results with it.
If that's not strong enough, switch to Flitz polish.
To prevent rust in the future, use Renaissance Wax.
