My Tarwar (made by Bura) arrived today, just a few hours ago, but I cant resist posting a few initial impressions. Fit is excellent, finish is good, (the degree of polishing varies a bit on the two sides of the blade), blade is absolutely straight, and the primary bevel is symmetrical.
The handle is made out of oak with a very nice grain and a very smooth finish; it feels a little large for my hands (3.75x 7.25), but I can safely control the blade. The only minor imperfection is on the handleward side of the small oval brass tsuba, which has a slightly rough finish.
The scabbard is sturdy and well build with a chape that might serve well as a weapon in its own right
; tooling is ok, but not overly fancy. The frog is interesting. The belt loop is fastened with 6 rivets to the scabbard loop, and the heads of the rivets on the inner side of the belt loop are even covered with a piece of leather in order not to scratch your belt nice touch. The frog is constructed for horizontal carry. If worn on a normal belt, it hangs around a 30-40° angle and is quite comfortable.
The only testing I have done so far was cutting 8 mm thick (0.32) pine plywood against the grain, and this was pretty impressive. Cuts mostly were around 10 cm (4) deep, not too bad, considered the makeshift set-up of the plywood (leaning on two small rocks, and the board was only 10 high, so hitting the board on the floor was somewhat awkward).
Much more work to do! This is a short sword on steroids (have you ever had this urge to browse through your wardrobe, searching this black coat, roam through the streets at night, looking out for hostile trees, fenders, cow-spines, melons, bears - wait, did I just say bears? Help, I am getting carried away!) What about a warning label: Careful, steel with an attitude?
Blade: 52.5 cm long (20.75), thickness tapering from 9mm to 5mm, width 3.5 cm (1.4) near the hilt and 4.5 cm (1.8) at the widest point
Handle: 20.5 cm (8)
Point of balance: 14 cm (5.5) in front of the tsuba
Center of percussion: Hard to measure objectively, since the blade is too thick to vibrate noticeably, but Id guess somewhere around 8-10 cm (3-4) back of the tip
Weight: 1.1 kg (2 lbs, 6 oz)
btw, has anybody ever found a good excuse for a shaved left forearm?
[This message has been edited by Anton Irmen (edited 05-28-2001).]
