Team Gemini Grind
Hello Team Gemini owners !
Please tell me about the grind on Team Gemini.
Is it nicely flat and gradually thinning going from the fuler down to the sharp edge ?
Or is it similar to the Boss Jack Proto with fuler ? Thick, bold convex grind ?
If you own both, how much is the edge different between these two models in your opinion ?
Any pix of the edge would be highly appreciated !
THX !
I believe that the Team Gemini is thicker at about .25" thick. This does have a fuller and overall is similar to the NMSFNO, it does gradually thins down but is not a convex edge, I think it was a standard V-grind.
I believe that the Team Gemini is thicker at about .25" thick. This does have a fuller and overall is similar to the NMSFNO, it does gradually thins down but is not a convex edge, I think it was a standard Busse V-grind.
Fixed that for you.
One side of the V will probably be at 20* and the other at 35* - get your diamond rods ready :D:D:D;)
Just kidding around, well sort of... hopefully the CG ganzaaa offerings will have gone under the new sharpening measures in which case they will cut you if you look at em funny :eek:
That sandy CG BWM is calling my name....
I really like the Team Gemini as well. Looks awesome in all 3 colors even... Good luck to everyone. Im hoping they got plenty of these and the BWM. Sandstone is starting to grow on me.
Thanks but take not that I'm curious about blade factory grind and not sharpening.
I hope that obscure times of diferential sharpening :p are long gone and all knifes that are currently shipped out of Busse are razor sharp.
V grind is like full flat ? With a fuller of course...
