Tec-loc question...
Fletcher Knives
STEEL BREATHING BLADE MAESTRO
Moderator
Will someone please do me a favor and measure the holes, center to center on a large Tec-loc and let me know what the distance is. Thanks in advance.
What I'm looking for is the distance between the top and bottom hole on the side, and from the top hole on one side to the bottom hole on the other side for the diagonal distance. I really just need to break down and buy one of the damn things. I'm trying to drill my sheaths so that you can mount a Tec-loc either vertical, horizontal or diagonal.
Inch and a half from top to bottom center of hole to center of hole. Same for side to side. Diagonal seems to be 2 & 3/8ths.
If my math is correct and the distance between the top hole and bottom hole is 1.5", then the distance between the top right and bottom left hole, since it's a right angle and both sides are equal distance, should be just shy of 2" (1.936")
See kids, Geometry is NOT a worthless class and this stuff does apply to the real world.
My bad mate
37.7mm horizontal
37.7mm vertical
54mm Diagonal
Might work better in inches!!!
Just make a template. If they're like the small tek-lock with three rows of three holes. Just space them 3/4" center to center all around and you'll have your template. Much cheaper than buying one.
