You should mention what uses you intend this knife to perform and things like that.
I own a Tech bowie and a Seal team elite. The Tech bowie comes very sharp out of the box, as mentioned. I have broken the tip of mine a time or two, it is Extremely sharp, and will pierce your finger at the slightest touch, but it's also a bit weak. I bent the tip a small bit just stabbing plastic bottles and such.
Seal team elite is a different class of knife to me. The tech bowie is a bowie.. different blade shape, and the handle is very nice, and grippy. I also love the cap on the end of the tech bowie, very nice, the knife is also very beautiful all around.
The seal team elite seems very sturdy. Tip appears to be much stronger than on the tech bowie, I really wouldn't be worried about breaking it. I actually havn't done much with my S. T. Longer blade, and note the notches on the top, you may not like that. Flatter coating, compared to the shiny coating, on the T.B.
UMMM sorry, im doing this all from memory.
T.B. comes with standard Sog kydex sheath with a nice belt attachment, my
S.T. came with a nylon sheath, set up for MOLLE attatchment, hence I stuck it on one of my packs, and haven't used it much.
Both are great knives man, same price range, probably same steel, both made in Taiwan... so I'd suggest thinking about which style you like best and will suit your needs more.
TB is more classy and beautiful, ST is more Badass and ready to go to work.
hope that helps.
