Technical steel question.
So I am trying to get more into the metallurgy side of steel. I am wondering what makes some steels softer? Like for example 14C28N would be considered a softer steel than say CPM154 even if both were hardened to say 58RC right? I was wondering what in the steel makes it softer? Also can some steels be given a harder tempering say 62RC and perform better than another steel at the same hardness? I have a CPM154 blade hardened to 62RC and I notice no chipping problems at all it seems super tough. Sorry if this is the wrong section but I want to start learning some of the technical sides of the steel. By the way it may be a while before I can chime back into the thread our internet is down right now, so I am not trolling.
thanks
Steeley
Softer may not be the correct nomenclature. Differences in two steels at the same hardness level will come from the alloying elements, namely carbides.
I think what you are referring to is due to carbide content. 14C won't develop carbides as readily as S30V and other steels, giving the steels that develop carbides the edge even at the same hardness.
There are people that know a LOT more than me on this site, and I'm sure they'll be along shortly to correct/add to my info.
The hardness is the hardness.
What you are seeing is a difference in wear resistance. Not the same thing as hardness.
The wear resistance of an alloy is improved by formulating it such that there are carbides in it. This typically means having an alloy with more than 0.77% carbon. Below that level, most of the carbon stays in the steel matrix, and is not available to form carbides.
You can think of it as the difference between cement and concrete. Steel without carbides is like cement. Steel with carbides is like concrete. The aggregate in concrete is more wear resistant than the cement holding it together. And concrete is more wear resistant than pure cement. But pure cement can be shaped to a sharper corner. So it is with steel. Alloys without carbides don't wear as well, but they take a fine edge with less work. Alloys with carbides have better edge retention but are harder to put a super fine edge on.
I think that this is a good reading list to start with.
http://www.hypefreeblades.com/bib.html
Metallurgy Books
Atlas of isothermal transformation diagrams
the United States Steel Company.
A compilation of transformation diagrams of many common steel alloys, with descriptions of hardenability, and various phases created by cooling from the austenitic phase.
Elements Of Hardenability
M.A. Grossman
An in-depth examination of the nature of steel hardenability which includes chapters on hardenability tests, the nature of hardening, the nature of the quenching process and the effects of alloying elements on hardenability.
Heat Treater's Guide
ASM Publication
ISBN: 0871705206
A compilation of data for each of the standard AISI grades of irons and carbon, as well as alloy, tool and stainless steels. Each data sheet gives the chemical composition of the alloy, a listing of similar U.S. and foreign alloys, its characteristics, and the recommended heat treating procedure. Most of the compilation goes much further and offers a wide variety of additional heat treating data such as representative micrographs, isothermal transformation diagrams, cooling transformation diagrams, tempering curves and data on dimensional change.
Metallurgy
Bert J. Moniz
ISBN: 0-8269-3506-0
Metallurgy covers all aspects of metallurgical engineering including the three areas of extractive, mechanical, and physical metallurgy. The textbook covers both theory and applications of metallurgical principles as applied to the conditioning, design, identification, selection, testing, and processing of metals and alloys. Topics include heat treatment, crystal structures, phase diagrams, materials standards, specific alloys, nondestructive and destructive testing, and fabrication methods. This new edition also covers the latest improvements in laboratory and industry techniques and equipment and adds new content valuable to metallurgy technicians and engineers.
Metallurgy Fundamentals
Daniel Brandt
ISBN: 0-87006-922-5
Metallurgy Fundamentals provides the student with instruction on the basic properties, characteristics, and production of the major metal families. Clear, concise language and numerous illustrations make this an easy-to-understand text for an introductory course in metallurgy. Over 450 tables, diagrams, and photographs show both the theoretical and practical aspects of metallurgy. This is perhaps the easiest to understand of any introductory metallurgy texts, Kevin Cashen says he uses this as his textbook for all of his bladesmithing metallurgy classes.
Quenching and Martempering
the ASM Committees on Quenching and Martempering
Includes chapters on methods of quenching, mechanisms of quenching, testing and evaluation of quench mediums, water and water based quench mediums, oil quenching mediums, gas quenching, factors effecting cooling rate, quenching equipment, maintenance of quenching installations, quenching of induction heated parts, quenching of flame heated parts, safety precautions, martempering methods and mediums, operation and control in martempering and equipment and handling in martempering.
Steel Metallurgy for the Non-Metallurgist
John D. Verhoeven
This book explains the metallurgy of steel and its heat treatment for non-metallurgists. It starts from simple concepts—beginning at the level of high-school chemistry classes and building to more complex concepts involved in heat treatment of most all types of steel as well as cast iron. It was inspired by the author when working with practicing bladesmiths for more than 15 years. Most chapters in the book contain a summary at the end. These summaries provide a short review of the contents of each chapter. This book is THE practical primer on steel metallurgy for those who heat, forge, or machine steel.
Tool Steel Simplified
Frank R. Palmer & George V. Luerssen
World's best selling handbook of modern practice for the man who makes tools and dies. This classic text presents detailed topics covering heat-treating methods and equipment; physical characteristics of tool steel; selecting the right tool steel for each kind of tool; properties, heat treatment, and testing of tool steel; hot acid etch test; spark testing; timbre and hardenability tests; furnace atmosphere; quenching and tempering; troubleshooting; etc. 535 pgs. Illustrated.
Contemporary Knives
An Edge in the Kitchen
Chad Ward
ISBN: 978-0-06-118848-0
An Edge in the Kitchen is the solution – an intelligent and delightful debunking of the mysteries of kitchen knives, once and for all. If you can stack blocks you can cut restaurant quality diced vegetables. If you can fold a paper airplane you can sharpen your knives better than many professionals. If you are willing to be a little adventurous you can find modern kitchen knives that outperform anything ever produced. Veteran cook Chad Ward provides an in-depth guide the most important tool in the kitchen, including choosing the best kitchen knives in your price range, practical tutorials on knife skills, a step-by-step section on sharpening, and more-all illustrated with beautiful photographs throughout. Along the way you will discover what a cow sword is, and why you might want one; why chefs are abandoning their heavy German knives in droves; and why the Claw and the Pinch, strange as they may sound, are in fact the best way to make precision vegetable cuts with speed and style. An Edge in the Kitchen is the one-and-only guide to the most important tool in the kitchen.
Messerklingen und Stahl
Roman Landes
ISBN: 978-3-938711-04-0
A ground breaking work in modern applications of steel for knife edges supported by almost a century of studies on that specific topic. Thus far it is only in German.
