Our classic SERE design in a fixed blade version, the SERE Operator features S30V steel with a full-length perimeter tang for maximum strength. The SERE Operator has a synthetic sheath system designed for ambidextrous carry in vertical, horizontal or diagonal modes. It can be customized to be attached on a belt, pack or load-bearing equipment or just about anywhere you can think of - even inside the waist carry for maximum concealability. The systems extender mounting plate can be easily drilled to allow the user full freedom to customize their attachment point(s). The SERE Operator is supplied with the sheath, attachment clip, secondary rubber retainer and extender mounting plate and is one of the most versatile sheath systems available today.
I have been considering this. I have a perfect design in mind that I think would work for my purposes even better than the loops that Blade Tech and Knivekits sell. Only problem is that I haven't got a clue where to buy a small amounts of Kydex.GarageBoy said:I don't think you can? You could try to make a screw in "hook" from kydex
Well heck, that makes too much sense not to try it! Not to mention that there is no shortage of paracord around my house.Tom Krein said:Brian,
The Tek-Lok won't work IWB. I will tell you what I do on my knives and you can try it out..........the only hang up is that it is really expensive.
O.K. so it is really no expensive. Infact it is down right inexpensive AND it works great. Get a small section of para cord and make a loop that will reach from on of the upper eyelets and go around your belt. Tie it off and burn the ends and the knot a little with a lighter or match. Now push the end of the loop farthest away from the not through the eyelet and pull the not throught the loop. It should be fastened to the sheath now.
Stick the sheath IWB and run belt throught the loop. This is a very low tech, and low cost method that works REALLY well. Very comfortable. Allows the sheath to move with you some.
If you find it moving to much for your taste add another loop to the back of the sheath. This costs soo little you can play around with it some.
Tom
