tek lok
faca
BANNED
Hello I wish to know the layout of Tek Lok( big and mini models) fix holes.
Thanks.
I only have a large teklok. Here is the layout. There are 7 holes layed out like this. There are seven holes. Using the hinged side as the "top". The top three holes center to center are .75" apart, the center hole is .75 from the CL of the top row, and the bottom row is 1.5" from the CL of the top row. I hope that this helps. I drew a diagram, but it did not post correctly so I erased it. I hope that this helps.
Faca - these are pretty cheap if you get them from Blade-Tech. This way, you know you have the right layout. You could conceivably do all sorts of drilling on whatever it is you are doing and then wind up with a mess when you finally try to mate it with a Tek-Lok and it's off just a scosh.
