Tek Loks, Large and Small..... A question for Mike Sastre , Normark and others....
Both Tec-Locs will work with holes drilled one inch on center (Did I say that right?)
In other words, the center of both holes will be one inch from each other...
Running Dog
Originally posted by Running Dog
Of cource this is just for the simple, straght, Vertical or Horizonal carry...
I just compared a regular TekLok to a mini-TekLok. As far as I can see a set of 1"-on-center holes will only accomodate the regular size in the vertical position, using the "slide" grooves. Am I missing something here?
--Bob Q
Bob, you may be right...I was working from memory...
It turns out I only have Mini Tek-Locs on hand so I can't be sure...
Maybe you could post the specs for us...I was sure you could use it both ways with a 24mm spacing (1 inch)
Running Dog
Hi MDP..
No the two different Tek are not the same hole patterns...
You can make the large fit the holes of a small Tek by using say the top hole and a slot,, but you have to drill the slot,, it's not made to slide up and down.The slot is too narrow and a Chicago screw will not fit into it...
I imagine there are some other positions,but couldn't tell you off hand.All of the large Tek I have get taken off and pitched into a box...Can you tell I don't like them ?? :)
Now the mini Tek are Way cool and have some valuable psibilities...
Good little piece of gear...
ttyle
Eric...
