- Feb 28, 2006
Hi Folks,
I read about temper tongs in a Nick wheeler thread. Anyone use them?
As I recall, Nick described them as two 4" long pieces of 1" square stock welded onto tongs. They're heated up in the forge to red hot then used along the spine of the blade while the edge is submersed in water.
I get the idea of using them to draw the hardness of the spine back. (The thread was about the making of an ABS test knife, which needs to bend to 90° without breaking through.) As I understand his use of the, he did a full quench on the whole bade and a full tempered of it. Then he drew back the spine further.
What I'm fuzzy on is what the target temp is for the spine to draw it back with the temper tongs, and how you know you've reached it? If the temper tong's bars are only 4" that must mean you have to work them along the blade. Is it done in one heat of the temper tongs? Etc?
Thanks for your input, Phil
