Generally speaking my question is:
Which is toughness difference of a low bainite and a properly softened martensite as a blade spine in general?
I know, that the answer easily is just: It depends.
I specify a more precise example because of that:
Let's suppose a carbon steel 1 %C.
The max hardness supposed to be HRC 65.
The HRC 50 spine has got quenching and by differential tempering (somewhere around 700F).
On the other hand, we can get the same HRC about 50 with bainite quenching the spine to some temperature (probably to something around 650-700 F). Again the edge is supposed to be martensite.
The more specific question now is: Which is the difference in toughness between the two blades? The HRC 50 both.
Can a bainite be tempered and how?
Use of tempering a bainite?
In the both cases we temper the edge properly to somewhere 350-400F.
Here we supposed that we are able to do both bainite quenching and differential tempering right and succeed to do it in practice.
pig
pig
