It doesn't work well to do what you describe with a HT oven.
It would probably work sort of OK if you built a programmable controller for a toaster oven and used it to do the tempering. They cool down pretty quick. Something like 2 hours
at 400F; 1 hour at 80F (effectively off); 2 hours at 400F; OFF
Can I setup a schedule on my kiln to temper at say 325 for 2 hours, turn off for 4 hours, and then temper again at 325? Or will the slow cool down in the heavily insulated kiln effect the temper?
One concern I have about this is the PID overshooting the target temperature, especially if it is operating in a range it is not tuned for. I use a PID that does double duty on a lead pot and it overshoots by twenty degrees on the tempering oven if it is tuned for the lead pot. Even if it is tuned for the oven, there is some slight overshooting on the initial heat up. I always let it get up to temperature about half an hour before I plan to put the blades in. Might not be an issue with your controller, but could not hurt to check before attempting this.
At tempering temperatures you can check with an oven thermometer.Without verifying that with a separate thermocouple, I wouldn't trust a heat treat oven to be accurate at tempering temps.
Am I wrong?
Am I wrong?
