I'm making hunting knives. 4-5" blades.what sort of knife are you making?
at 450 you're probably getting into tempered martensite embrittlement, so you're losing hardness and toughness. i use 1095 for fine slicing kitchen knives, so would temper around 350f.
there's a lot of info about the metallurgy on knife steel nerds that you might find useful (https://knifesteelnerds.com/)
So if I understand right you do 2, 1 hour tempers and allow to cool to ambient temp between the 2 cycles. Making knives is a lot more science than I thought. Thanks for the help.First off, don't worry about TME, that requires much higher tempering.
Second, always do two tempers. It is needed to get a complete conversion from brittle martensite to tempered martensite.
Depending on the use and desired hardness, anywhere in the 400-450°F range is OK.
Do both tempers at the same temperature.
I do hunters in 1095 at 400°F for a final hardness of Rc63/62. 450°F will drop that down to Rc 61/60.
Welcome to Knifemaking.So if I understand right you do 2, 1 hour tempers and allow to cool to ambient temp between the 2 cycles. Making knives is a lot more science than I thought. Thanks for the help.
Yes, but it's OK to cool the blade off under running water between the cycles so that you don't have to wait for it to air coolSo if I understand right you do 2, 1 hour tempers and allow to cool to ambient temp between the 2 cycles.
