Hi guys I'm back with another AEB-L question. I heat treated 12 blades and need to temper them but find conflicting tempering temps. I have written down that 325 should hit 61 but that seems low to me. I also can't recall where I got that number from when I wrote it down. Here's my process so far.
-Preheat kiln to 1965
-Place foil wrapped blades in kiln, allow to come back to temp
-When kiln and blades are at 1965, start 15 minute soak
-Pull blades and quench between 1x4x18 aluminum plates.
-Once I can handle, fully cool in water, remove from foil and place in dry ice and alcohol for an hour.
I don't have a hardness tester yet but they are damn hard and a Nicholson file won't cut at all. I'm struggling to come up with a tempering temp for these so am currently running a 325 cycle for an hour just to try to stress relieve them. 6 blades are fillets in .070, and 6 are hunters in .130. What would you recommend for temps and hardnesses for these? This is my first real attempt at AEB-L and I managed to lose all my info I had compiled somehow. I really appreciate any help anyone can offer here.
Lastly, I have some warps I need to correct. They were pretty good off the plates but warped a bit again when they went into the subzero. I have a straightening jig I made from angle iron, but I'm wondering if I would be better to clamp flat and temper, or overbend for the temper cycle. I could go straight and then overbend if needed, I'm just trying to save some time doing it right the first time.
