cgdavid said:I hear these terms used and not exactly sure what they mean. does anyone have good definitions and why they are used?
Distal taper - Peter covered this pretty well above.
Slack belt grinding - Using the unsupported belt where ther eis no platen or wheel under it to get a convex grind or edge.
Convex grind - Also called an appleseed grind, it tapers in towards the edge as a curve that bellies outward, giving a profile like the cross-section of an appleseed. Some people grind the whole blade this way, others just the edge.
Thanks! Curt
miden said:Good questions Curt and good replies. I was never too sure about the distal taper thing, now it is crystal clear, thanks.
Anybody got info about the slack belt question? Is it just when you use the belt between the drive wheel and the platen or contact wheel???
Lovely taper there Jim. Must have been quite a mission.
Mike :thumbup:
shgeo said:Distal tapers may also run both directions from the ricasso, or just involve the blade.
