- Mar 12, 2013
Hey all!
I had a thread the other day where I was asking for advice about avoiding crazing or whitening around the pin holes during the peening process. Several people recommended that I switch to Corby bolts. I had some miniature corby bolts that I had ordered previously but never used, so I thought I should have a look at them again and see if I could get them to work for my knives.
Given that the fasteners were so small I was a little worried about their strength, so to satisfy myself I did some destruction testing yesterday, and also took a video of it!
The question of just using epoxy by itself has also come up several times. I've tested this in the past and didn't have good results, but I wanted to test it again on video... Surprisingly the results were different this time, you'll have to see for yourself!
Warning! Knife abuse ahead
[video=youtube;PGmydrLT2Fo]https://www.youtube.com/watch?v=PGmydrLT2Fo[/video]
I'm pretty sure that pop that you hear at 1:57 in the video is actually the fastener nearest to the ricasso breaking in half. The other fasteners held though. The fasteners were at a serious disadvantage during this test as the tang on that scrap blade was tapered which means that the bolts were slightly bent during installation. I bet that proper installation in a tapered tang, or on a flat tang would be even stronger.
Thanks to Elementfe for the tip about sanding the epoxy into the tang and scales, seems to work well!
EDIT: The corby bolts I used were these ones from Jantz - http://www.knifemaking.com/product-p/cp627.htm
