Here's your chance for some input. I'm going to be testing all of my S30V blades, in response to an older thread. After the S30V blades, I'll be running VG 10, ZDP 189, D2, and probably some others through the same tests. This will be a test of edge retention and probably stability as well. Anything that comes to light during the tests that is interesting will be investigated. Here's what I'm planning, I'm looking for comments, ideas, and anything that I might be forgetting.
1. Finishing all knives to a common, repeatable sharpness. For me, that means using my Edgepro. I will test both polished and rough edges (grit sizedly speaking). Polished means up to and including the standard 3000 grit tape. I'm still open on rough. Testing the edges will probably mean measuring phone book push cuts. I just got a bunch dropped off from the phone company, so last year's books will be the media. If this proves ineffective, then I'll probably try thread cutting.
2. Cutting at first will be using sisal rope purchased from Lowes. I'll try to purchase it all at once to hopefully minimize variation. I haven't yet decided on 3/8 v.s. 7/8, etc. The rope will be cut on the softest 2x4s I can find to minimize edge distortion.
3. For now, I'll measure the factory edge angle on my edgepro and record it. Maybe in the future I'll make all the knives the same angle, but we'll see.
I've got photobucket set up, and will try to have pictures when helpful to illustrate the process. The current plan will be to sharpen a knife, test cut, and measure. I plan on 3 runs rough, 3 runs smooth for each knife. I don't know how many test cuts will make for good dulling, I'm thinking of measuring every 20 cuts or so until completely dull. Every sharpening will be to remove weak metal, no steeling or any of that nonsense.
I would like to do some cardboard testing and carpet testing, but don't have reliable sources yet. I will probably add more metals to test, but this should keep me busy for several months.
Any comments or suggestions are welcome. If you would like to see a particular knife tested, then be prepared to send it to me. I'm not buying any more knives to satisfy anyone's curiosity. And for the record, I'm not testing INFI, unless it's at the end. When I've got calluses worked up. In case you're wondering about that comment, Jerry Busse cut around 1700 pieces of rope at a knife show with an INFI blade without dulling it. I'm quite sure that S30V will be at least an order of magnitude less. We'll see.
