- Feb 1, 2000
I recently heat treated a hunter made from 5160 using the triple normalize-triple quench-triple temper and I have some doubts about the knife, but they may be foundless.
After the third quench the file test seemed to be o.k., but it's hard to tell sometimes when the blade is coverd by a thin coating of scale and possibly a very thin skin of soft decarbed steel. I'm always certain of 1084 with the file test, it's always glassy hard. 5160 seems different, perhaps a bit softer after the third quench?
After sharpening, the edge survives the brass rod test fine, but after chopping into a 2x4 a bit I get a bit of wire edge curl over toward the tip that is easily stropped away and after wards doesn't get dull after additional chopping (I didn't chop it in half by any means with a 4" blade but I did do a lot of chopping)and even seems to get a little sharper after several push strokes into the pine 2x4.
However when I finished it to 600 grit the hardening line didn't pop up like I expected (like I get on 1084) but it is barely visble running in a straight line from a point about one third the length of the blade back from the tip to a point at the the ricasso about a .250" above the edge. Is a light hardening line to be expected on a triple quenched blade?
I was trying to finish this blade up to take to Batsons Bladesmithing Symposium and maybe sell, but I don't want to finish it up if the heat treat is in question. So what further test would you guys suggest? Push and/or draw cuts using manila rope? How many cuts through a material like that should a knife with good edge holding charachteristics be expected to make before dulling appreciably? If it were any other steel I'd just do the heat treat over but the triple-triple-triple deal is no casual?
