I have one that should be here tomorrow and plan on trying to sharpen a Kershaw Shallot with somewhat of a recurve blade using the triangle ends. Should I use the 40 degree setting? Any suggestions are appreicate as I have never used one nor sharpened free hand in 30 years?
Just watch the DVD included with the sharpmaker, it will clear up any confusion. On a side note, I use my sharpmaker slightly differently than shown on the DVD. Rather than making alternating passes I just sharpen on one side at a time until I form a small burr along the entirety of the edge then do the same on the other side. At that point you can make alternating passes to remove the burr and move on the the next finer grit and repeat. I also highly recommend the ultrafine rods as they definitely help a ton in getting that next level of sharpness as well as the diamond rods if you plan on doing a lot of reprofiling.. Other than that, practice, practice, practice.
Certainly start with the 40. If nothing else, it keeps the stones farther from scratching the sides of the blade.
The Sharpmaker handles recurves as easily as straight edges. Tips? Keep the blade vertical. Maintain a steady but light pressure. A good rhythmic stroke makes all this easier.
Later on, turn the base over and lay the stones in the two parallel grooves, and you've got an improvised benchstone to practice on. A ceramic benchstone. (Don't start free-handing using diamond.)
As a bonus, don't forget to sharpen old scissors and nail-clippers. I rejuvenated an old potato peeler!
Thanks for the info but I just realized that I dont think it has the dvd with it. I found it slightly used but wont know for sure until it gets here.
+1I have always been inept at sharpening knives. The Sharpmaker has fixed that problem for me. The device and its enclosed DVD with instructions helped me immensely! Thank you.
