Pen,
I don't know what your problem was with the cable Damascus, ( Not that I haven't had some problems my self) At this point I have seen rusted and galvanized used with fine results. By people with skills. One thing my Teacher will not attempt is "non twist cable" a type used in cranes. The core twists one way and the jacket goes the other.
Some of the coolest I have seen of late are some of the Teacher projects in this knife smiting class. One a bit "sewer snake" that was wrapped with bailing wire , had a snake skin look. That just holds the eye.
The other was two slabs of cable with a slab of spring and strapping for the core. When this was etched the center layers are darker and the cable did not look so cable like as it has drawn out. Net effect was a tanto that could be mistaken for a old Japanese build.
Ferrous,
how's the bike chain cutting? photos?
My cable,bearing,spring KLO is waiting on me making some mosaic pins and a bolster.
During this time "off" I tried a cable handle Damascus, all one bit of cable.
I got the first bit of cable to drawn out, and so tried to fold it over to give the blade some more mass. The end result is a handle that got a little hot and burned some of the strands with a blade that looks great on ONE side the other side has the folded thin end of the cable that did not weld well.
I think it will be a good user if the bad side comes off there should be enough blade. By using it I think I will learn more then if I chucked it.
My cable,bearring,spring KLO is waiting on me making some mosic pins and a bolster.
Durring this time "off" I tryed a cable handle damascus, all one bit of cable.
I got the first bit of cable to drawn out, and so tryed to fold it over to give the blade some more mass. The end resolt is a handle that got a little hot and burned some of the strands with a blade that looka great on ONE side the other side has the folded thin end of the cable that did not weld well.
I think it will be a good user if the bad side comes off there shoud be enough blade. By using it I think I will learn more then if I chucked it.
