Goodmorning,
First, thank you to the vets that clued me into the enthusiastic rush I made into the forum. I initially came across as a billborad. Not my intention, and I thank the folks who explained to me what was transpiring.
Now, onto the technical stuff. I am using Nicholson Files (new) to try out my first few real blades. Pre heating them to a blue-ish color, then grinding and working them. have not gotten to the heat treating yet.
The reason for the use of te files is the immediate availability and ease of form to begin the initial stack removal. I know there has been a lot posted in the past about this subject, and I also know that a file is not the best material to use, but I am very limited financially. Using a small 1/3 hp grinder, files and whet stones.
Can someone give direction to me on how to do tis correctly. Having a hard time establishing a good solid flat bevel for the edge. Also, the file "markings" are very difficult to remove with the machine that I have, and I have heard from many people that these will cause stress risors and cause a real problem when final heat treating is applied.
One last thing, is water treatment the manner to treat a file and if so, can I selectively treat the piece to form a hard edge and springy spine.
thanks for the help. And thanks for the initial guidance on protocal. (sp?)
William
William
