- Sep 4, 2010
I have a lot of folders and fixed blades, but didn't have a really large fixed blade apart from a machete. After reading some threads about choppers, I wanted to try one out. I generally don't mind paying for quality and most of my stuff is $100+, but for my first really large knife I decided to test the waters in the ultra cheap class.
I ordered the MTech USA MT-20-08s from my LKS. It was $15.90 out the door.
It dwarfs my RC-4:
Here are some approx specs:
Blade length: 9 3/4 in
Overall length: 16 in
Stock thickness: .157 in (4mm)
Grind height: 3/4 in
Blade width: 2 in
Weight: 19oz (23 w/ sheath)
Balances just in front of the guard, or right on the logo
Marked "440 Stainless"
In the rear grip, my hand is a full 3in behind the cutting edge.
The tip is very, very close in shape and thickness compared to the Para2.
I have only had this for a few days, but I got right down to business. Only complaint is that the handle scales came loose and started to rattle immediately. This was not unexpected, as even some of the product descriptions mention that "handles are loose," but it appears there is no adhesive at all, just the two pins holding the scales in place. I would have gladly paid an extra dollar or two to have the scales glued on!
Undeterred by a little rattle, I pressed on. I will fix them up later.
Batoning, no issues, even with blows falling on the thin tip:
Chopping on seasoned firewood, no issues. Actually preferred it to a Fiskars X7 hatchet:
Shredded and chopped up a can. Take that, stupid can!:
I did a fair amount more chopping than I can show. It also worked well on brush and small branches. Apart from the handles, all the grinds on the blade are nicely finished and even. The edges around the guard, choil, and spine were all a little sharp, making it somewhat uncomfortable when I choked up to strip some bark and whittle with it. I fixed that up easily with a file. Only took a few minutes and the knife is much more comfortable now.
So far it's held up fine, excellent really, for a $16 knife. Easily surpassed my expectations. No visible damage to the as-boxed edge during use. It still slices paper just like it did before I started. It was decently sharp out of the box, but below shaving. It should perform even better after some work on the bevels and re-sharpening.
Not trying to say it's the greatest thing out there. I suppose the next time I take it out it might fail on the first whack. Still, I feel like it performed well for what it is.
Thanks for reading.
It dwarfs my RC-4:
Blade width: 2 in
Thanks for reading.
