- Jan 12, 2011
As mentioned, I re-profiled my Acies ZDP-189 to 30* inclusive using the WEPS.
I do not have magnification other than that little illuminated portable microscope from Radio Shack. I don't need magnification to see the scratches in the bevel from the re-profiling.
My question is, in going back to now remove the scratches is it safe to assume that the finer grit paddles will in essence ride on the ridges of the scratches removing material down until the scratch is memoved?
If this logical assumption is correct - what methodology and what grit would you use to remove the scratches knowing that the bevel and angle is set.
I assume that by doing this process I may also get to this hair splitting smoothness as well. Because I can also assume that scratches translate to micro-serrations in the edge as well ( can't have a laser smooth edge with scratches I would think)
Lots of stuff in there but bottom line is smoothing out the edge and mirroring the bevel.
