The Battle Of The Multi-tools
Thanks to K man’s incredible generosity, I had the opportunity to check out the SOG PowerLock and Gerber 400 Compact Sport multi-tools as part of a pass around lottery (thanks to Dave H. for organizing it). I decided to pit the PowerLock against my Leatherman Super Tool 200 and Victorinox SwissTool for this review (the Gerber 400 was reviewed separately HERE).
These are the three tools most recommended when someone asks about a full sized, full featured, “heavy duty” multitool, so I think it will be an interesting contest.
- THE CONTENDERS –
- SOG PowerLock S60 –
http://www.sogknives.com/pwrlck.htm
- Leatherman Super Tool 200 –
http://www.leatherman.com/products/tools/super-tool-200/default.asp
-Victorinox SwissTool –
http://www.swissarmy.com/webstore/moreinfo.cfm?product_id=2107&category=39
- THE MATCH UP -
The three tools are well built and heavy duty as far as multi-tool go (although no multitool is truly heavy duty compared to specialized heavy duty tools). All feature locking tools and are of roughly similar weight and bulk. (Overall, I would say that the PowerLock is the bulkiest followed by the SwissTool and Super Tool. The SwissTool weighs in at 9.8 oz., the PowerLock at 9.5 oz. and the Super Tool at 9 oz. nominal.)
The Super Tool 200’s strong points are handle comfort and very nice screw drivers.
The downside to the Super Tool is its tool clumping and difficult to disengage lock.
The SwissTool’s big advantage is the ease of tool access (without unfolding the handles). The lock release is also very easy to use, allowing closing tools easily with one hand. The handles are also very comfortable and there is no tool clumping.
The SwissTool’s disadvantages are its small pliers, slippery screw drivers, poorly designed Phillips driver and wire crimper. The SwissTool is also the most difficult to get the pliers open with one hand.
The PowerLock has several innovative features not found on other brands of multi-tools, these include: 2:1 compound leverage gears for the pliers, hex bolt construction which allows individual tools to be removed from the handles and a ¼” drive.
The SOG’s weak points, as I see them are handle comfort (due to exposed compound leverage gear teeth), inconvenient tool access (due to handle “wings”), and tools which could use improvement (wood saw, file, screw drivers, awl, and especially, scissors).
– OPERATION –
The PowerLock can be flicked open Bali Song style, but was adjusted a bit too tight, so it usually took me a couple of tries to get it fully open. The PowerLock’s handles need to be unfolded to access the tools and the handle wings have to be unfolded to open or close the tools (they also make it hard to see the tools in the handles). Most of the PowerLock’s tools clump together when opened.
The Super Tool’s pivots seem to be adjusted just right, not too tight to flick open without being too loose – this is a good thing, since unlike the PowerLock, the Super Tool’s pivots are not readily adjustable without special tools. Like the PowerLock, the Super Tool’s handles have to be unfolded to get to the tools. All of the Super Tool’s tools clump.
The SwissTool is too tight to flick open with one hand, but I can open the SwissTool one handed by brushing the handles along my hip – not as smooth a move as flicking but it works. The SwissTool’s pivots are riveted, so there is no adjustment. The SwissTool’s implements are easy to access from the outside – no unfolding of the handles and no clumping.
- LOCKS –
The SwissTool uses a bolt action type lock, which is released by sliding back the metal lock release tabs about 1/8”. This is an excellent multitool lock (a similar system is used by Gerber). The SwissTool’s lock is easily disengaged and tools can be closed safely with one hand (although it takes two hands to open them).
The PowerLock has a lock back style rocker lock that works well and is fairly easy to disengage.
The Super Tool’s lock is something of a chore to disengage to the point of being dangerous if you are not careful. The Super Tool has an integral spring lock in the back of the handles that works sort of like a lock back, except that there is no locking lever to release the lock. On the original Super Tool, you disengaged the lock by unfolding one of the other tools half way, which pried the integral lock out of engagement, allowing both tools to be folded back into the handle.
Leatherman attempted to improve the Super Tool’s lock release when they redesigned it into the Super Tool 200, by adding thumb levers to each handle which allowed the locks to be pried out of engagement without having to open one of the other tools (although you can still use that method with the 200 if you prefer). The levers are nearly as awkward as unfolding another tool and make safely closing tools with one hand difficult. The levers also rattle a bit and add bulk.
- HANDLE COMFORT -
I would rate the Super Tool and the SwissTool in a dead heat when it comes to handle comfort. The Super Tool 200’s rolled edges are big improvement over the original Super Tool which had irritating unrolled edges that would dig into your hand. The Super Tool 200’s handles fit my hand well but there is a little bit of unrolled edge left where my index finger and the web of my hand goes. The SwissTool is comfortable thanks to a fully rolled edge, but feels a little big and blocky.
When driving screws, both the Super Tool and SwissTool are comfortable, with a slight advantage going to the Super Tool.
The PowerLock has unrolled edges but dose have a pair of (removable) aluminum “wings” that cover the edges for a comfortable feel. Unfortunately, the rear edges of the wings tend to dig into my hand and like the Super Tool 200, the upper part of the unrolled edges are exposed (not covered by the wings). The wings are easily removable (in fact one of them popped off a few times on its own), but without them you are left with uncomfortable handle edges much like those on the old version of the Super Tool. In my view, the wings represent a Band-Aid solution.
The most uncomfortable area of the PowerLock handles is end with the compound leverage gear teeth which dig into the palm when using the tools in the handles. This is a problem not only when using the screw drivers and awl, but also the wood saw and file.
– TOOL BY TOOL –
PLIERS - The PowerLock’s pliers are not only the largest (inside jaw length = 1 13/16” from base to tip) of the three tools but they also opens the furthest, measuring 2 3/16” from tip to tip when fully open, or about 63 degrees. The PowerLock also has the advantage of 2:1 compound leverage, so the grip is tighter than tools without this feature.
The Super Tool also has fairly large Pliers ( 1 11/16” inside length, approx. 48 degrees and 1 ¾” tip to tip when fully open), but there is, of course, no compound leverage. The tips of the Super Tool’s Pliers are only about half as wide as those of the PowerLock, making them easier to get into tight spaces. Unlike the PowerLock, the Super Tool’s Pliers are dressed finely enough to pluck hairs from my arm.
The SwissTool has comparatively small (1 3/8” inside jaw length, approx 45 degrees / 1 7/6” from tip to tip when open) truncated needle nose Pliers that are about 50 % wider at tip than the PowerLock’s.
WIRE CUTTERS - Both the PowerLock and the Super Tool have similar wire cutting sections at the base of their plier jaws. Both measure about 5/16” in length and have small notches for hard wire cutting. The SwissTool’s wire cutters measure only about 3/16” and have no hard wire notch.
The biggest wire I had around was some 12 gage (.081” dia.) copper wire; and all of the multi-tools cut this without breaking a sweat.
The SOG seemed to cut very slightly easier than the Leatherman and the Victorinox, likely due to the compound leverage, so I would rate the PowerLock first in this category.
I rate the Super Tool over the SwissTool due to the extra 1/8” length of the wire cutter and the hard wire notch.
WIRE CRIMPER – I used the crimpers to crimp some 14-16 gage (blue) connecters.
The PowerLock crimper really crimped the connecters on tight, thanks to the compound leverage.
The Super Tool’s crimper performed adequately but it was a little difficult to get a good tight crimp.
The SwissTool dose not have a real crimper - just a little space between the handles where you can mash a connector and this dose not leave a tight or well formed crimp.
KNIFE BLADES - Both the Super Tool and the SwissTool have separate plain edged and full serrated edged blades, while the PowerLock has a 50% serrated combo blade, since the scissors take up the space for a second blade.
Overall, I like the SwissTool’s blades the best. Both of the SwissTool’s 3” blades are the familiar SAK style flat ground spear point blades, one plain edged and the other with the little Victorinox “wavy blade” serrations. These blades are ground thin and cut very well. Since the SwissTool’s blades open from the outside of the handles when folded, there is no lower handle to get in the way when cutting. Unfortunately, Victorinox missed out by not outfitting the blades with studs or holes for one hand opening.
The Super Tool 200 also has separate 3” plain and serrated blades; the plain is a clip point and the serrated is a sheepsfoot pattern with mild Spyderco style serrations. Both blades have high, slightly hollow grinds. I like the idea of a sheepsfoot shape for the serrated blade for situations where a pointed blade is undesirable.
The PowerLock has a single 50% serrated combo 2 9/16” drop point blade. Like most combo blades, the straight edged portion has a single bevel (sharpened on one side only), and this is a disadvantage for most purposes.
SCISSORS - The PowerLock is the only one of the three multi-tools equipped with scissors (in place of a second knife blade); although the SwissTool is available with scissors in place of the serrated blade as the SwissTool X.
To give the PowerLock’s scissors a good work out, I tried them on phone book paper, 32 lb. cardboard, monofilament fishing line, rubber bands, string, shoelace, paracord, and denim jeans.
I also hauled out every tool with scissors that I had for comparison; these included a Leatherman Mirca and Wave, a Victorinox Classic and Huntsman, a Wenger Handyman and the Gerber 400 Compact Sport Multi-Plier which is part of the same pass around/ lottery as the PowerLock.
The PowerLock’s scissors were by far the poorest performing of the group. They felt wimpy and they often jammed closed with out finishing the cut and the exposed wire spring seems to be vulnerable to damage. The SOG’s scissors were the only one that failed to cut through the paracord or cotton shoe lace (the Gerber 400, Micra and Wave sometimes took 2 tries to get through the paracord and the Wave sometimes took two attempts to get through the shoe lace, but the PowerLock would not cut through even with multiple attempts). The PowerLock was the only scissors that sometimes took several tries to get through ¼” wide rubber bands. The PowerLock’s scissors were only barely able to cut the cardboard and felt like they were going to bend. The SOG scissors even performed poorly on paper. The cuts are snippy since the throat is only about 7/8”. The PowerLock’s scissors where the only ones that world not cut denim at all (the other scissors were all capable of cutting denim easily and all were able to cut through the hem with varying ease or difficulty).
The PowerLock’s scissors aren’t worth including on the tool. I would like to see SOG come up some better scissors or replace them with a second knife blade.
BOTTLE OPENER - Both the PowerLock and SwissTool have bottle openers (combined with screw drivers) much like those found on SAKs. The Super Tool dose not have a separate bottle cap lifter, but the can opener is supposed to be good for both cans and bottles.
The PowerLock and SwissTool bottle openers seem to work well, while the Super Tool’s combination can/bottle opener is marginal, at best, for bottles. The Super Tool’s opener just barely gets a grip on the cap and easily slips off.
Continued......
CAN OPENER - If I had a lot of cans to open, I would prefer the Leatherman can opener, since it was a little faster than the other two and left slightly smoother edges on the can/lid, even though it lacks the little screw driver tip found on the SwissTool and PowerLock openers.
The SwissTool has the usual SAK type can opener (with the little screw driver tip) that cuts toward the tip (the Super Tool opener cuts away from the tip). This can opener was fast and left relatively clean edges.
The PowerLock opener is similar to the Victorinox type, but did not cut as well and left the most jagged edges.
SCREW DRIVERS - The Super Tool’s has the best standard screw drivers; these consist of 5/64” ( 2 mm ), 13/64” ( 5 mm), and 9/32” ( 7 mm) widths. All of the Super Tool’s screw drivers serve there purpose well and are generally longer than the PowerLock’s and SwissTool’s drivers. Unlike the other two tools, none of the Super Tool’s drivers are combined with the can or bottle opener.
The PowerLock also has three screw drivers: a stubby 3/32” (2.5 mm) driver on the can opener tip, a 13/64” (5 mm) on the end of the can opener, and a 9/32” (7 mm). All of these are functional but short (1 1/8” overall for the 5 and 7mm’s); and the usefulness of the little 2.5 mm on the can opener tip is even more limited.
The SwissTool has four standard screw drivers: a 2 mm, a stubby 3 mm on the tip of the can opener, a 5 mm on the end of the bottle opener and a 7 mm. All of these are over polished with rounded edges and are plated like the rest of the SwissTool’s implements. This means that they slip much too easily. The SwissTool’s screw drivers can be improved by sanding off the plating and squaring up the edges with a file.
PHILLIPS SCREW DRIVER - Both the SOG and Leatherman Phillips drivers grip screws securely. The SOG appears to be #1 size and Leatherman is said to be sized for both #1 and #2 screws and looks to be a #1 size with a slightly flatter tip. The Super Tool’s Phillip has the advantage of length over the PowerLock (1 7/8” overall vs. 1 9/16 for the SOG). The PowerLock’s handles are also much less comfortable for driving screws, due again to the compound leverage gear teeth.
The Phillips driver is the SwissTool’s worst performing tool - not only is the tip plated and slippery, but the head is cut out of a flat piece and seems to be designed to slip.
AWL - I used each tool’s awl to bore holes in a 1/8” thick leather belt and a ¾” thick pine board. The SwissTool’s awl was the sharpest and worked the best. The Super Tool ‘s came in second because it is not as sharp and it’s steep taper made it harder to drill through the wood board. The PowerLock came in last. The PowerLock’s awl has the longest shank (1 5/16” vs. about 1 1/8” for the SwissTool and 1 1/16” for the Super Tool), but it is not very sharp, nor is it as an efficient design as the other two awls. Again, as with the screw drivers, the PowerLock’s gear teeth made it harder to work with.
WOOD SAW - I tested each tool’s saw by cutting up a 1 ¼” diameter hardwood snow shovel handle.
The SwissTool’s saw was the most aggressive and the SwissTool performed best both in terms of speed and comfort. The SwissTool’s saw has an effective length of 2 11/16” and 29 teeth for about 10.8 teeth per inch. The SwissTool’s saw is about 0.051” thick.
It took an average of 36 full (push and pull) strokes on average for the SwissTool to cut the shovel handle. Much as with the knife blades, the SwissTool’s saw is aligned with the lower edge of the folded handles, which could be an advantage when working in a tight spot.
The Super Tool’s saw has an effective length of 2 5/8” and 29 teeth for about 11 TPI. The Super Tool’s blade is .046”thick.
The Super Tool took an average of 53 push/pull strokes to cut the hardwood handle. The Super Tool was somewhat more comfortable to use than the SwissTool, but its saw was also appreciably slower and less aggressive.
The PowerLock was a distant third in speed and comfort, taking an average of 93 saw strokes to cut the shovel handle. To make matters worse the PowerLock’s compound leverage gears raised a small blister on my hand after 3 or 4 cuts.
The PowerLock’s saw blade is also 0.046” thick, with an effective length of 2 3/8” and 36 teeth for 15.2 TPI – this is much less aggressive than the other two saws, accounting for the additional saw strokes.
I also tried each saw on some ½ -3/4” green hardwood branches. The SwissTool and Super Tool performed well on these branches even though the teeth clogged. The clogging did not prevent either saw from cutting, but it did make it more difficult. As with the shovel handle, the PowerLock’s saw performed relatively poorly, taking much more effort to complete the cuts. The PowerLock’s finer saw teeth clogged more easily than the coarser Victorinox and Leatherman saws, but again, the saw was able to continue cutting even when clogged.
FILE - I tried each file on some scrap brass and aluminum and for these materials, I liked the Super Tool’s file the best. The Super Tool’s file has an aggressive double cut pattern on one side and a finer single cut on the other. Unlike the PowerLock and SwissTool files, the Super Tool’s file teeth extend to the tip, with an effective length of about 2 ½” (3 1/16” overall).
The PowerLock’s file pattern is similar to the Super Tool and works about as well; except that the effective length is only about 2 1/8” (2 5/8” overall).
The SwissTool’s file also worked well - both sides are fairly fine double cut patterns with an effective length of about 2 7/16” (2 15/16” overall). I would prefer a coarser file on one side.
METAL SAW - Each of the files is notched on a third side (edge) so that they can be used as a metal saw. I tested the metal saws on common framing nails.
The SwissTool’s metal saw (2 9/16” effective length) cut much quicker and with less effort than the other two files. Victorinox claims to use casehardened steel (with a hard chrome finish for rust resistance), so they are likely harder (more akin to a “real” file) than the other two.
The Super Tool’s metal saw ( 2 7/16” effective length) came in second, followed by the PowerLock , which for some reason has only notched/ effective length of only 1 5/8”
WIRE STRIPPERS - The SwissTool has two sharpened wire strippers, one is U shaped and the other V shaped; both are combined with the chisel. The SwissTool also has a little unsharpened SAK type wire stripper (sometimes more appropriately called a wire bender) on the bottle opener.
The Super Tool has a single sharpened V wire stripper on the can opener.
The PowerLock has no wire stripper, although the serrated portion of the knife blade could be used as such.
RULERS - Each tool has metric and inch rulers on the handles, all are graduated in mm’s and 1/8” increments.
The SwissTool rulers measure 9” or 22.8 cm tip to tip when extended and are easily read with very nice straight edges on both the inch and metric side – undoubtedly the best rulers I have seen on a multitool. The only thing I don’t like about the SwissTool ‘s rulers is that there is not enough friction to keep the Pliers from opening under the weight of the handles when extended, so you need to hold the SwissTool handles or pliers in place to keep the two handles together when using the extended rulers.
The Super Tool rulers also measure 9”, but are on the back side of the handles instead of the sides like the SwissTool and PowerLock. There is no true straight edge, but the rounded handle corners are straight enough for drawing straight lines. The Super Tool’s handles taper in near the pivots so the edge and ruler markings are not continuous (there are no ruler marks between 4 and 5”).
The PowerLock’s handles measure 9 5/16” when fully extended with both inch and metric marking on the same side of the handles. On the PowerLock, the pliers and compound leverage gears get in the way of the rulers, leaving a gap in the ruler markings between 3 3/8” and 6”. The inch scale is on outside of the handles, so the edge is rounded like the Super Tool’s but the metric scale is on the inside edge of the handles, so you have a straight edge there. Unfortunately both edges are interrupted by such things as the pliers, gears, wings, locks and nail nick cutouts. However, the wings can be used as straight edges. In fact, the wings could serve as protractors had SOG provided some markings for this purpose.
LANYARD ATTACHMENTS – The Super Tool has an excellent lanyard ring that folds out through the back of the handles. When not in use the Super Tool’s lanyard ring is out of the way behind the wood saw, and since the ring is under the rolled portion of the handle, it takes up no space that could be used for tools that fold out of the handles. The Super Tool’s lanyard hole measures .190” in diameter – large enough to accept a piece of paracord.
The SwissTool provides for lanyard attachment with a couple of .130” diameter holes in the plier springs located in the upper part of the handles. These holes are too small for paracord and are intended for use with split rings so that a lanyard can be tied or clipped to them. It was very difficult to get a SAK split ring through the holes in the springs and once attached the split rings often get in the way when closing the knife blades or the saw or file (depending on which side the ring is installed on). The ring also makes the SwissTool a tight fit in its belt pouch. This is not a very satisfactory method of attaching a lanyard.
I could not find a lanyard ring on the PowerLock at all, although the SOG catalog says it is supposed to have one. I am assuming that the PowerLock normally uses a small lanyard ring (which accepts a split ring) that attaches under one of the handle bolts, much like on the Pocket Plier. If so, it is a better arrangement than the SwissTool but not as good as the larger diameter ring on the Super Tool.
CHISEL/ SCRAPER - This tool is a SwissTool exclusive. This shaving sharp chisel is great for working with wood and can be used as a scraper.
¼” DRIVE - This a nice feature exclusive to SOG. The ¼” drive allows using standard sockets with the PowerLock and a standard adapter (not included with the tool), will accept standard hex bits.
Although I don’t have them, there are hex bit adapter sets available for the Super Tool and SwissTool. The Super Tool uses a special adapter (sold separately) that takes hex bits and Victorinox offers a bit driver and bit set that fits in a special belt pouch along with the SwissTool Plus (this is not an adapter as such since the driver dose not attach to the SwissTool; instead it is used independently).
- BELT POUCHES –
The SwissTool came with a functional, though thoroughly mediocre black Cordura pouch with a shiny red Victorinox logo snap which looks out of place.
The Super Tool came with a typical Leatherman clunky/lackluster black leather pouch with a brass snap. Apparently, the Super Tool is also offered with a nylon pouch which at least looks better.
The pass around SOG did not have a pouch, so I can’t comment.
- RUST RESISTANCE –
None of the three tools showed any signs of rusting during the week long review, although the pass around Gerber Compact Sport did develop a few small, faint rust spots on the pliers and handles. The SwissTool is plated and I have never had a problem with it rusting. Most parts of the PowerLock also appear to be plated but there was a bit of rust on the file. I have had Leatherman files, knife blades and plier heads all rust a little in normal use.
- THE SCORE CARD –
OK, let’s see where the 3 tools stand so far.
The PowerLock has the best Pliers, wire cutters, wire crimpers, bottle opener (tied with the SwissTool) and gets points for its exclusive compound leverage, ¼” drive and hex bolt construction (removable tools).
The Super Tool has most comfortable handles and has taken the screw driver (standard and Phillips), file, can opener and lanyard attachment categories.
The SwissTool has the best knife blades, awl, wood saw, metal saw, wire strippers, rulers, and bottle opener (tied with the PowerLock), plus the exclusive chisel/scraper. The SwissTool also has the most convenient lock release and tool accessibility.
AND THE WINNER IS…..
All three multi-tools are well made and designed and each of their manufacture deserves credit for a job well done. Choosing the “winner” will depend on which features that you value most and which weak points you can live with.
Overall, I personally favor the Victorinox SwissTool slightly over the other two mainly because the tools are by far the easiest to access and I am willing to accept the SwissTool’s small Pliers, lousy Phillips and the slick (but easily fixed) screw driver tips. I would love to see Victorinox provide the SwissTool with one hand opening knife blades.
I would put the SOG second place. The PowerLock has several innovative features such as the compound leverage, ¼” drive and removable tools that I like, along with some that I don’t, such as the handle wings that make tool access more cumbersome and the compound gear teeth which are uncomfortable when using the tools in the handles. I think that the PowerLock would benefit from eliminating the wings and going to rolled handle edges; this would allow better comfort and easier tool access. I also think that some of the SOG’s tools (especially the scissors) should be improved.
I would rate the Super Tool a very close third. The Super Tool’s Pliers and tools are high quality and everything performs well. The Super Tool 200 also has the most comfortable handles. The main thing that I dislike about the Super Tool 200 is the unlocking of the tools – the levers on the handles are a pain and I think Leatherman could do better.
Thanks again to K man and Dave H. for the pass around and lottery!
- Frank
Gerber 400 Compact Sport Multi- Plier Review -
http://www.bladeforums.com/forums/showthread.php?s=&threadid=274908
Wow! that may be the most compreshensive comparison I've seen done between multitools.
Thank you!
Thanks Dave.
Owen, I would have to test several of each tool to destruction to find out what it takes to make the pliers fail and how they fail. I can say that the PowerLock’s pliers are the most substantial and look to be the strongest, but I don’t know how strong each tool’s pivots are. The SwissTool has the smallest pliers, but they may have the advantage of stronger tips since they are thicker due to their truncated needle nose profile.
The SwissTool’s large (7 mm) screw driver is by far the sturdiest, because it is thick, wide and short (1 ¼” L x ½” W x .098” thick) – in fact Victorinox also calls this driver a “crate opener”.
- Frank
Originally posted by OwenM
Any comments about which has the stoutest screwdrivers, particularly the large flathead.
I second the recommendation on the Swiss Tool's large screw driver / crate opener. It's a solid little bugger as far as multi-tool screw drivers are concerned. I find myself using it frequently to pry things open and what not. I have the SOG multi tool and I was never that impressed with it other than the pliers. The Swiss tool delivered the quality I was used to with their SAK's. I got it with the sheath which includes a handy little driver set. I got mine before the X version came out with scissors. I think I might go for the X version now. While the serrated blade is great for cutting through heavier things like boxes and rope, the scissors would be a welcome substitution.
Nice review Frank :) Very well done.
I've been carrying a SwissTool for over 2 years now after switching from the LM SuperTool. I've also found I can't live with the SOG's blister inducing handles.
I wrote a review/comparison of the SwissTool X and the Leatherman Wave a while ago and I thought I did a pretty darn good job. Your review blows mine completely out of the water.
VERY good job. Thanks for taking the time to do this.
-John
PS - I'm still keeping my SwissTool X!!!
Nice job Frank, lots of information on a few tools which I had been considering. Outside of the crimping, did you notice the effect of the compound leverage on the SOG. Functionally where there ever tasks which you could not perform with the others, but were possible with the SOG, or similar significantly easier.
-Cliff
Thanks for all of the compliments on the review, I’m glad that so many of you liked it.
Cliff, the PowerLock pliers seemed to grip a little harder and wouldn’t slip as easily as the other tools, but how much more pressure they are capable of producing became obvious when using the electrical crimper.
- Frank
Really indepth review, Frank! Thanks!
A new Powerlock comes with a leather sheath very similar to the Leatherman.
I like my Powerlock but I agree that the teeth are a nuisance. Also, I got so much use out my original Leatherman SuperTool pliers that I don't know that I need the compound effect on the Powerlock.
I found the unlocking mechanism on my Pulse (the same as the SuperTool 200) wasn't hard for me to use at all. It isn't as easy as the Victorinox or Powerlock, though.
Thanks for the excellent review, Frank. I agree with you about the Swiss Tool's chisel/scraper. Though it's kind of and oddball tool, in the sense that no other multitool has anything like it, I find it to be one of the implements that I use most. It's very versatile.
One thing that I like about the Wave/PSTII (probably on the supertool as well but I don't have one) is the file is much better for sharpening small fish hooks than the Swisstool.
Hooray for the SwissTool. I knew I wasn't wrong when I bought one about two years ago!
Esav, thanks for the feed back and info on the SOG sheath!
Nathan, the chisel/scraper dose come in handy! This is something other Multi-tool manufactures should emulate.
phwl, the Super Tool dose not have the diamond coating on one side like the Wave and PST II.
Golok, The SwissTool is my favorite also, but I don’t think that any of these three tools is a bad choice!
- Frank
Frank,
That is the advice I usually give. I have and love the SwissTool X and I always reccomend it, but I also always tell people that I have tried a lot ot Multi-Tools and I really haven't found any that were just 'bad'. Most of the tools out there are very good, which I think is shown by the fact that so many people have so many opinions about which one it 'the best'. Some are better than others of course, but I think it really just comes down to features and tool selection.
-John
The steel in these tools works very easily, I turned the large screwdriver on a Rucksack into a chisel in a few minutes.
-Cliff
