That 3V Bravo 1 will be a tremendous workhorse once you get the hang of it! Take your time, the stuff is AMAZINGLY abrasion resistant. Diamonds are NOT necessary, conventional stropping media will be effective, just much slower than it would be on a lesser steel.
The benefit is that it takes equally long to LOSE that tremendous edge. If you've been working it with a diamond stone, chances are that the convex nature of the blade has been altered quite a bit, which will likely take more time in the stropping to correct. I sharpen my 3V CS using 3m Trizact belts, and leather belts loaded with CrO and Boron Carbide, so from first-hand experience I can tell you that they ARE effective. Just takes some time.
If you're up in Central Washington, I'd be more than happy to put an edge to it for you, and show you how to keep it up with a hand strop. It's not hard, it just takes patience and a light touch.
