The Biggest Mess I Have Ever Made
PDE
Well, every so often a family friend, he does tree removal, brings us a great big load of wood, all cut and read for the fire. I was going through and splitting some various logs, all long leaf pine. I came across a little fatwood in one. I was wondering where the hell it came from, so I started examining the other logs. I noticed one about a foot and a half in diameter and it had a big old wound where a limb was removed. I took my axe and chopped at the area around, greeted by a resinous aroma and the dark color of fatwood. I got excited, went in the house, grabbed a fiskars collapsible saw and my fallkniven S1.
The log was roughly three and a half feet long. The place where the limb was removed was in the middle, so I sawed a line two inches deep around the whole log. Then, took my SFA and split off these small sections of wood. I did this on both ends, and several minutes later I reached fatwood. The grain was no longer visible, just a uniformity of reddish orange. I shaved some off and lit it up. All I had on me at the time was a bic. It put off the telltale black smoke of fatwood, simultaneously setting the resin to bubble and sputter. It is some of the best I have ever found, burning for several minutes.
My method took forever! I just made do with what I had at hand, too lazy to head in the garage, besides I was not ready to gum up a chainsaw. I then found some less impressive fatwood in the other sections of the log. After processing for several hours, I still have along ways to go. It is amazing, I must have enough fatwood to last me years. I would say it probably around fifty pounds worth of stuff. I was left with black hands and tools that need to be cleaned and scrubbed, as well. It was worth it, I just have to put away the axe, saw, and knife( which I used to baton out the choicest sections of fatwood.) I will probably finish up the process tomorrow when I get a chance, I still have to clean the tools too. It was hot today, 70 degrees with 80% humidity. Hopefully it will be cooler tomorrow.
Just thought I would share today, sorry was not in the mood to gooey up a camera to take pictures of it.
Anyone else get out today to do anything today and practice any skills?
PDE, buy you some quart size freezer bags & sell the stuff on the 'Net. Our family reunion this summer is at my cousin's farm in southern Ohio. It belonged to my grandparents in the 50's & it is still in the family. It is about 80 acres total, and about 25-30 acres of it's hills are nothing but pine trees. I can tell you right now I will be taking my truck this year and will be bring back as much fatwood as I can possible process in a week-end . . . :thumbup:
Only downside is like you said, the clean up. Haven't really found anything that will clean pine tar off 100%. Good luck with your adverture.
Be safe.
Be safe.
Its funny,I was honestly thinking about selling it as well, but I might do a
little give away.Acetone seemed to work pretty well for clean up. If you pour it on the place your sawing it seems to cut it nicely and the only bad part is that you have to deal with the fumes wafting into your eyes and nose. I probably would not try this with a chainsaw, I think you might get a spark and catch it a fire, or the friction would make it light up. I will probably just give most of it away to friends now that I think about it, I got a couple who would appreciate the work and time that has to be put in to getting the product.
Thanks JUST1MOR for the reply, always appreciated, Thanks Again.
Kerosen will take care of residual fatwood gunk on saws and knives.
one an also dilute their chainsa bar oil 20% with kerosene to prevent gumming up.
Acetone is definitely open air work mateial. I used to use this back in the day to soak my bowling balls in before they started using a durometer to check the hardness of the shell . . . :D
Damn things would hook on ice if they had too.
Be safe.
