Fred.Rowe
- May 2, 2004
I built this jig after a frustrating begining as a bladesmith. :yawn: Not being able too produce the same grind on both sides of the blade. That is the idea isn't it? Anyhow, after a little wrestling with the gray matter, I came up with this. The guide/clamp thingy, made from a C.s.X. R.R. cotter pin, rest along the side of the planten helping to control that angle. The bubble thingy controls the pitch of the blade as you grind. You notice I built 4 of the b.t.
There is a degree difference in the top of the wood blocks, this gives me a wide enough range to grind both narrow and wide blades. Once you lock the jig to the blade its just a matter of selecting the bubble, mounting it by way of the magnet to the jig or blade, placeing the guide against the planten, float the bubble and grind away. Your grinding skills will improve dramaticily.
I run this on a KMG grinder but with a little tweek, it should work for others.
If you need clarity let me know, I'll get back with you, Fred
